Water leak under dash
Old Aug 5, 2024 | 03:17 PM
Derzhoker's Avatar
Default Water leak under dash
Hello everyone, I'm probably bringing up an old thread but I need help. I
m having water leaking issues underneath the dash. I have 98 civic dx coupe. It started under the dash on the passenger side first but it sort of made it's way to the driver side. But it's mostly just the passenger side, it's starting to flood now . I also noticed that its also wet behind the center console (the floor is wet). I took my car for a wash a couple days ago so I wonder if a seal is not good because there is A LOT of water. It's been dripping a good amount everyday now. I also noticed that the black box behind the glovebox, it's very wet underneath it. So I wonder if it's that thing. Also today, I heard something new. When I turn left, something sounds kind of like dry fart?? Like it sounds clogged and it's trying to get through. But one thing is for sure, when I turn left, a lot of water starts dripping in the floor. Any advice helps! Looking to take off the dash for a closer look
Old Aug 6, 2024 | 08:24 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Water leak under dash
Have you checked you coolant level? I wonder if your heater core is leaking.
Old Aug 8, 2024 | 01:59 AM
youstolemybeer's Avatar
5 Year Member
[QUOTE=Derzhoker;52859139]Hello everyone, I'm probably bringing up an old thread but I need help. I
does your ac work? If it does, blow out the condensate drip tube, with either compressed air or a garden hose (the floor is wet anyway).
Old Aug 9, 2024 | 04:52 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Good tip! none of my old civics have AC so I don't have that drip tube that runs under the car in the center. If that is plugged it would definitely throw water inside instead of draining outside to under the car behind the steering rack. Seen it on other old civics I've ripped parts from.
Gonzalez206
Dec 4, 2017 05:14 PM
91DxRob
Sep 30, 2013 01:21 AM
mattbatson
Aug 10, 2009 11:42 AM
wilntegra
Sep 5, 2004 06:25 PM
Pearce
Feb 26, 2002 02:17 PM
