Honda CR-V & Element 2WD & 4WD Element & CR-V
Need Advice On 2002 CR-V Valve Adjustment
Old Jul 25, 2024 | 11:37 AM
CR-V Guy's Avatar
5 Year Member
Default Need Advice On 2002 CR-V Valve Adjustment
I'm going to be adjusting the valves soon on my 2002 CR-V. How are the cylinders numbered, what is the firing order and which cylinder is #1? Thanks in advance!
Old Jul 25, 2024 | 05:20 PM
Ryanthegreat1's Avatar
Default Re: Need Advice On 2002 CR-V Valve Adjustment
Cylinder 1 is the timing chain side. Then it's sequential to the transmission end. 1 2 3 4
Old Jul 26, 2024 | 11:54 AM
CR-V Guy's Avatar
5 Year Member
Thanks Ryan! Do you happen to know the firing order?
Old Jul 27, 2024 | 09:16 AM
seagiant's Avatar
Old Jul 29, 2024 | 06:52 AM
CR-V Guy's Avatar
5 Year Member
Thank-you for those responses. I adjusted the valves over the weekend and I'll see if it runs any better once I get it back together next weekend.
Question: any suggestions for removing the valve cover? I had to fight with the power steering hose to remove it so I'm wondering if you have any tips on this.
Also, just curious if you guys set your valves on the tight or loose side…maybe in order to prevent the exhaust valves from burning. I set mine in the middle, just wondering what you do.
Old Jul 29, 2024 | 09:13 AM
seagiant's Avatar
Hi,
The PS Hose is a PIA, no getting around that no matter how you handle it.
You should notice, better Idle, better Gas Milage, and no burnt Exhaust Valves!
Hard to beat that!
Old Jul 31, 2024 | 02:21 PM
ajchien's Avatar
I unbolt the PS hose from the pump, use a S hook and tie it to top to the hood out of the way.
Old Aug 1, 2024 | 06:05 AM
CR-V Guy's Avatar
5 Year Member
If you do that is there a gasket between the pump body and hose that needs to be replaced?
Old Aug 2, 2024 | 10:38 AM
chidog's Avatar
O ring, get that before starting the job, just like the cover gasket. I have reused it though.
Old Aug 5, 2024 | 08:19 AM
CR-V Guy's Avatar
5 Year Member
Next time I will definitely get that o-ring and unbolt the hose. Thank-you for that tip, I really appreciate it.
CR-V Guy
Jul 3, 2024 04:37 AM
NEDan
Honda Fit
Aug 4, 2017 06:30 AM
GSRVTEC1
Oct 31, 2005 01:19 PM
VTECorona
Aug 28, 2002 08:53 AM
