Leaking under distributor looks like RMS?
Will a leaky inner seal of a distributor look like a rear main seal. I redid my valve cover and finally added gasket on the four corners by cam caps.
I also changed out the o ring for the distributor where it meets the block. And inside the hole is all oil
i have pictures but can't seem to post on might be my data.
A leaking distributor can leak like a bad real main seal. Is it oily inside your distributor?
In my case, for some reason mine was still leaking even with a new oring and I had to put a light coat of hondabond on the oring to stop the leak on my 00 Civic
