Temperature level goes up even with the ignition
Old Jul 15, 2024 | 11:21 AM
vroman2312's Avatar
Default Temperature level goes up even with the ignition
Hi does anyone know why my temperature level goes high when I put the ignition and with the engine on stays up high. It happens always even when the car is totally cold after some days without using it. I check the temperature in a OBD scanner and it looks normal
Old Jul 15, 2024 | 07:43 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Temperature level goes up even with the ignition
What is the chassis ?
Old Jul 15, 2024 | 08:25 PM
vroman2312's Avatar
Its a sedan civic 98 D17y7 I don’t know if thats what you’re asking for
Old Jul 16, 2024 | 08:03 PM
JRCivic1's Avatar
10 Year Member
Community Builder
That works... the temperature gauge in the instrument cluster is driven by a single wire sensor on the transmission end of the cylinder head just below the distributor. The wire color should be yellow/red (stripe). If this wire is bare/exposed anywhere between the gauge and the sensor, it can "ground out" which drives the gauge needle all the way to HOT... or above. If this continues, the gauge itself may get damaged. If you see no damage to the wire close to the sensor, unplug it from the sensor itself and see if the gauge needle stops moving. If so, then the sending unit/sensor is bad and needs to be replaced. If the gauge needle continues to climb, you definitely have a short in the wire and you need to track it down.
Old Aug 12, 2024 | 09:47 PM
vroman2312's Avatar
Yes, in the end of the cable (where it plugs in to the engine) is exposed tomorrow I will try to put some tape on it.
xafbx
Jul 9, 2008 03:36 PM
tigueremalo
Jan 23, 2007 06:42 AM
Eg_TypeR
Sep 30, 2006 09:06 PM
Andre
May 27, 2005 06:06 PM
HondaH22A
Mar 10, 2004 09:38 PM
