Idling issues/P0505 *UNSOLVED*
Never thought I’d be the one posting here, as I almost always find a fix from someone else, but I’ve ran into an issue.
For starters, I have a 2000 EX sedan with a d16y8.
I manual swapped the car as the automatic transmission was failing. I replaced the harness, the intake manifold, the ECU and the transmission from a donor car.
yes, the intake is a 99-00 intake with the air injection ports and the big IACV on the IM instead of the throttle body.
I did it this way to keep it as OEM as possible with minimal wiring/hackjob activities lol.
my concern is, my idle is rough and the car runs terribly. It wasn’t doing this before I manual swapped.
I have checked my coolant levels,
bled the system
replaced the IACV (granted, with a Duralast unit, however the problems didn’t change)
And there is not a vacuum leak. I sprayed with bc and unplugged and replugged every line.
I have not adjusted the idle screw.
honda wants a new OEM IACV for $500. I don’t got that kind of bread.
but the car stutters while driving and it idles rough. Any help appreciated.
code is P0505. Thank you!
bled the system
00hondacivic5sp
Mar 24, 2023 04:31 PM
thewrai6th
Oct 28, 2018 05:32 PM
RocHatchDX
24
Jun 17, 2013 12:55 PM
