Integrating a 2001 Civic ECU with a 1992 Civic Instrument Cluster: Challenges and Sol
Old Jul 9, 2024 | 05:56 PM
pipe.vtec's Avatar
Post Integrating a 2001 Civic ECU with a 1992 Civic Instrument Cluster: Challenges and Sol
Hello, I need your help to see if it's possible to make the instrument cluster of a 1992 Civic work with the ECU from a 7th generation Civic D15B 1.7 VTEC. I bought this car with the engine swap already done, but nothing on the cluster works because nothing is connected. I wanted to know if you have the diagrams or pinouts to make it work. It's the original cluster of the 1992 Civic with the ECU from a 2001 7th generation 1.7 VTEC Civic
Old Jul 9, 2024 | 08:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Integrating a 2001 Civic ECU with a 1992 Civic Instrument Cluster: Challenges and
You have bitten off more than you can chew. Part of the 7G instrument cluster works off a multi-plexer whereas, the 5G cluster is fully analog. In order to make it work, not only will you have to properly wire all of the plugs, but this wiring would have to be extended into the engine bay and back to the fuel tank, and 5G sensors would have to be installed. I suggest you go to a salvage yard and pick up a 7G cluster... they are cheap and plentiful.
Sjalabais
Honda Civic (2001 - 2005)
Jan 14, 2016 01:13 PM
bayron
Jul 14, 2008 08:50 PM
Buckhorn2
Audio / Security / Video
Nov 1, 2005 05:08 AM
shant33
Jun 2, 2005 01:52 PM
