Rt t-lamp and ctr rear brake light stay on
Old Jul 5, 2024 | 01:00 PM
BubbaBob's Avatar
Default Rt t-lamp and ctr rear brake light stay on
My 92 Civic Hatch back had it rt rear tail lamp and rear center brake lamp staying on, while I discovered this double broken cone (in pieces) on the driver's floor just below the steering column. The two cones had a broken ring with blue coloring parts as the cones were also separated. Pulled the fuse for the lights. My hunch is the turn signal unit or perhaps a brake switch (?) perhaps. The cones are about 1/4" in length, maybe the same in width. I have attached two pics that may help. If my first hunch is correct, it would appear a new turn switch unit (got a good, reasonable source for that?) is required, meaning the steering covers have to come off, but can I do this without taking off the steering wheel which has an airbag...never removed one of these? How do I take off the top and bottom str column plastic covers? Thanks for your help...I certainly need it! Hope the pics give a good idea too.
Old Jul 5, 2024 | 01:05 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Rt t-lamp and ctr rear brake light stay on
Brake pedal switch stopper pad and clutch interlock switch stopper pad.
Old Jul 5, 2024 | 03:30 PM
BubbaBob's Avatar
Where is this part exactly located...and thank you very much for your quick response and accurate identification of those part pieces!
Old Jul 5, 2024 | 03:48 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
There are 3 stopper pads if you have a manual transmission.
The stopper pads are near the switches on the pedals. They work in conjunction with the switches.
Photo from ebay ad, with notes added.
Old Jul 5, 2024 | 07:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
New ones from Honda are WHITE and not Dark Blue.
Old Jul 6, 2024 | 02:24 PM
BubbaBob's Avatar
Hey, those pics will direct me just fine, most appreciative! I have the five speed manual, base model with same engine plus A/C with only 44,000 original miles, being the 2nd owner.
I take it the two cone shaped points that ended on the driver's floor that had broken rings (plastic) with blue color are part of something that you pointed to in those pics, right? If not, where would such items come from, just in case I have communicate incorrectly?
Again, thank you for your help, your sincere help!
Old Jul 6, 2024 | 09:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The Honda/Acura part number that you want is 46505-SA5-000. You will need TWO. You will push them into the open holes on both the brake and clutch pedal arms cone first... just in front of the brake light switch and the clutch start/interlock switch. The brake switch pad will be easy to install... the clutch switch pad, eh, not so much. Removal of the clutch pedal makes it really easy. If you don't want to remove the pedal assembly, do a search about replacing the clutch switch pad and you will find some MacGyver tricks on how to do it. IGNORE the posts about sticking a bolt in the hole instead. I have used a long flat head screwdriver with the blade wrapped in sticky-side-out duck tape, stuck the pedal pad to it, oriented it cone facing the pedal with the back of the blade touching the clutch switch pin, and pushing the clutch pedal toward the floor to force the pad into the hole on the pedal arm.
Old Jul 7, 2024 | 03:24 PM
BubbaBob's Avatar
JR, I will be going to the local Honda dealer this Monday...your information is terrific...if this works out you will be my new best friend!
Old Jul 7, 2024 | 09:38 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Tech8 got you on the right path... I just added more detail to help you finish. Happy to help.
g8rdude
Mar 27, 2024 03:08 PM
ZAPxRowsdower
Apr 12, 2013 07:54 AM
1998_4dr_gsr
Aug 25, 2011 09:15 PM
AccordEX1991
Jul 9, 2007 05:29 PM
hondachris01
Mar 25, 2007 04:43 PM
