Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Would a bad A/C Blower Fan, stop the A/C clutch from cycling?
Old Jul 5, 2024 | 08:14 AM
cfauvel's Avatar
Default Would a bad A/C Blower Fan, stop the A/C clutch from cycling?
My nephew had his a/c stopped working recently and it was initially diagnosed as a fault fan motor resistor. The A/C worked for a bit then stopped.
We diagnosed that the resistor was still working, via a test light going brighter with each click,
Then diagnosed that the motor was in fact bad, by applying a 12v D/C power source.
The question is would a bad fan blower, stop the a/c compressor from cycling, due to some lack of resistance from fan motor even the thought A/C button is on and fan control is on max?
Old Jul 5, 2024 | 08:18 AM
Ryanthegreat1's Avatar
Default Re: Would a bad A/C Blower Fan, stop the A/C clutch from cyling?
Evaporator probably feezes and causes a cut out.
Bo-Deker
May 9, 2014 01:44 PM
5w-30
Honda CR-V & Element
Aug 23, 2011 12:10 PM
uncl3j0n
Jun 21, 2011 07:01 PM
busted90accord
Apr 3, 2008 08:12 AM
