Honda CR-V & Element 2WD & 4WD Element & CR-V
Starts only using starter fluid
Old Jun 22, 2024 | 06:26 PM
LTDfire's Avatar
Default Starts only using starter fluid
2011 Honda Element.
I have to spray starter fluid into the intake before it will start.
Any suggestions?
David
Buffalo NY
Old Jun 25, 2024 | 12:16 PM
95_civic_gsr's Avatar
Default Re: Starts only using starter fluid
Originally Posted by LTDfire
2011 Honda Element.
If it was an earlier year model honda, I would suggest its a main relay.
Sometimes they just needed a bit of starter fluid to get the engine vibrating enough
to make the connection over the corroded cold solder joints in the old main relays.
Could be anything from old spark plugs to dirty injectors not atomizing though.
What all have you done recently, and when was the last tuneup?
RicerBoi16
Mar 29, 2020 08:35 AM
Big Dee
Sep 13, 2017 06:10 AM
masterjasper
Engine Management and Tuning
Oct 2, 2013 04:06 PM
NYCE
Feb 14, 2011 05:15 AM
92civeg
Sep 23, 2003 08:23 PM
