Honda S2000 Honda S2000
secondary air pump
Old May 26, 2024 | 08:20 PM
twinky_eg6's Avatar
Default secondary air pump
2003 ap1 having issues with secondary air pump monitor not ready. replaced pump and 2 hoses due to being damaged. The car does not have a check engine light on, hasn't had it on at all. checked wiring, relays and fuses. you can hear air pump turn on and off.
Drove vehicle multiple key cycles, over 100 miles freeway and street multiple times. I ended up buying a izze bypass modulator. Monitor is still shows as not ready. Unfortunately I need to fix this due to living in commiefornia and vehicle needing a smog every two years. Looking for input from people with similar issue and advice. Might sell car if it nothing changes.
Old May 26, 2024 | 10:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: secondary air pump
What ECU are you using ?
Old May 27, 2024 | 09:11 AM
twinky_eg6's Avatar
stock ecu, there is one more step I'm try which leads to ecu replacement if there's no voltage found at connector p32
trepteg
Honda S2000
Aug 24, 2009 12:36 PM
ma_rio44
Honda S2000
Nov 5, 2008 06:32 PM
MADBADGER
Honda S2000
10
Jun 27, 2008 04:57 PM
sounguy787
Honda S2000
Oct 12, 2006 12:40 PM
AKS2K
Honda S2000
18
Nov 9, 2004 10:14 PM
