Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Re-pack tie rod end with grease?
Old May 8, 2024 | 02:38 PM
010's Avatar
010
Default Re-pack tie rod end with grease?
Squeezed out a little bit of grease when I removed a fairly new tie rod end using a ball joint separator. Is it possible to re-pack an OEM Honda tie rod end ball joint with grease? How does one go about doing so?
Old May 9, 2024 | 06:29 PM
Silentz's Avatar
Default Re: Re-pack tie rod end with grease?
Losing a little grease is fine. Make sure your tie rod boot are not torn. You can repack them with grease by removing the clip holding the boot to the tie rod then slide the boot down.
firemanG
Dec 24, 2007 08:30 AM
HuskerHybrid
33
Dec 19, 2006 08:22 PM
SVOboy
11
Sep 18, 2005 05:09 PM
