Honda CR-V & Element 2WD & 4WD Element & CR-V
Crv upper bolt hole stripped for starter
Old Apr 27, 2024 | 06:00 PM
skymaster1991's Avatar
Default Crv upper bolt hole stripped for starter
Any recommendations how can re-thread this withiut removing the motor or another fix? Anyone run the lower bolt alone and start fine for years?
Old Apr 28, 2024 | 11:12 AM
Default Re: Crv upper bolt hole stripped for starter
buy a tap socket from amazon. a m10x1.50 tap. since i only strip the starting part of the whole. this resolved my issue.
Old Apr 28, 2024 | 05:23 PM
95_civic_gsr's Avatar
Some things you can try:
A pick set, sometimes the bolt is actually loose in the hole that it snapped off in, and can be backed out with a pick set.
Hot glue stick, sometimes you can use a lighter on the end of a glue stick, and heat it up and squish it onto the bolt, if its loose, and can then be backed out.
Ease outs or reverse drill bits. Sometimes they will start drilling the hole, and then they will grab, and back the bolt right out for you.
Sometimes they add friction heat as well and helps break the bolt loose.
if you end up drilling out the bolts, make sure you don't apply too much pressure to the smaller pilot bits. If you break one off in the bolt, that hardened steel will be a pain to drill through with the rest of your larger bits.
Old Apr 28, 2024 | 09:22 PM
something similar to these can work well if the project isn't too heavy duty.
Below are left handed drill bits and extractors. So if the drill bit bites into the bolt, it is backing the bolt out, not driving it into the transmission.
If these don't work, you may have to get square extractors, or weld a nut/bolt to the existing one, to get something to back out with.
Old Apr 29, 2024 | 06:32 AM
Ryanthegreat1's Avatar
Dude, reading comprehension.
nitewolf
Oct 8, 2014 06:37 PM
playaP
Aug 23, 2008 12:37 PM
90Integra
May 31, 2006 07:04 PM
hoehouseworker
May 15, 2005 06:57 PM
