Honda Accord 2018- Current This is the place to discuss all things Honda Accord related for the 2018- Current model year
How to reset a throttle body sensor with OBD2 tool after cleaning???
Old Apr 16, 2024 | 04:44 PM
hermtm2's Avatar
Default How to reset a throttle body sensor with OBD2 tool after cleaning???
Hello guys,
I have 2019 Accord Hybrid which has 155,000km(95,000miles).I feel that the fuel mileage has slightly dropped compared to last year. It used to show 21-23 km/l from spring to fall on the same route.
For getting back the fuel milage to normal, I plan to clean up the throttle body. Although I can’t find any tutorial videos or information, I bought OBD2 device(NT710) and chemicals.
The issue I’m encountering is how to reset the throttle body sensor with the OBD tool after cleaning.
If you have an experience with NT710 tool, please help me out.
Thank you,
Un.
Old Apr 19, 2024 | 02:21 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: How to reset a throttle body sensor with OBD2 tool after cleaning???
1. Select the PGM-FI System with the HDS.
2. Select the ETCS (TAC) TEST in the Function Test with the HDS. <<<<<<< look for this function in your aftermarket scan tool
3. Select TP POSITION CHECK and clear the throttle position (TP) learned value.
4. Turn the vehicle to the OFF (LOCK) mode.
5. Turn the vehicle to the ON mode, and wait 2 seconds without pressing the accelerator pedal.
If the above function is not in your scan tool(it likely wont be in a lower end scanner) then youll need another scan tool.
Old Apr 19, 2024 | 02:47 PM
hermtm2's Avatar
I will check it with my scanner.
Thanks.
Old Jul 10, 2024 | 12:24 PM
Ruyke's Avatar
On Honda Hybrids, you just let the car idle for about 10 minutes while it's adjusting the throttle after the PGM reset
Old Mar 16, 2025 | 04:34 PM
hermtm2's Avatar
My scanner has the function, “TP re-learn”. It took me about 10 sec.
Thanks,
Ryan.
MrJDM_
Dec 8, 2010 12:05 AM
seldon
Oct 18, 2008 09:42 PM
aznlaoboi315
Jan 25, 2008 03:11 PM
bumsta217
Aug 2, 2007 09:49 AM
B_CRUZ!
Northern California (Sales)
Dec 13, 2005 07:34 AM
