Skunk 2 Intake and TB on a y7
Old Mar 18, 2024 | 12:15 PM
worley's Avatar
Default Skunk 2 Intake and TB on a y7
I have a 97 del sol with a d16y7 in it. I mistakenly wanted to swap out the stock intake and tb for skunk 2 ones. It has a stock ecu and an iacv block off because the 2 wire iacv does not work with obd2. I now have an obd1 ecu with hondata so I can wire up the iacv. My question is where do the two hoses on the iacv go to? On the setup I have now the coolant bypass hose and intake manifold coolant nub are routed to the bottom of the skunk 2 throttle body. Should I just move the hoses to the iacv and nub off the throttle body ports?
Old Mar 18, 2024 | 07:15 PM
theYBLEGAL's Avatar
Loved
Default Re: Skunk 2 Intake and TB on a y7
No coolant to either iacv or tb. Bypass both. Ensure your tb has no fitv and if so block it off.
worley
Feb 25, 2024 08:38 AM
Stopsign32v
Apr 9, 2021 11:29 AM
HighhBrid
57
Mar 19, 2014 12:14 AM
DJBLUEB20
May 10, 2013 12:31 PM
MKIIISupra
Aug 9, 2005 08:18 AM
