Weird headlight problem , one comes on one goes off ?
Old Mar 17, 2024 | 04:53 PM
Sprinxyzzz's Avatar
Default Weird headlight problem , one comes on one goes off ?
Weird problem with my 97 ek hatch OEM headlights
when I turn the stock to put my lights on one comes on
when I put my brights on , one goes on and one goes off
the video explains better. Any reason why??
Old Mar 18, 2024 | 09:48 AM
Sprinxyzzz's Avatar
Default Re: Weird headlight problem , one comes on one goes off ?
bump
Old Mar 18, 2024 | 12:32 PM
spAdam's Avatar
Loved
Community Favorite
Is this something that recently began? Or has it been like this as long as you've had the car?
Old Mar 18, 2024 | 12:34 PM
Sprinxyzzz's Avatar
just begun
just checked the wiring no breaks or issues , checked all my under dash + under hood fuzes no issues
maybe it’s the bulbs? They small like a burning smell : get super hot.
turn signals work good , hazards , and rear lights all work.
Old Mar 18, 2024 | 05:46 PM
spAdam's Avatar
Loved
Community Favorite
Sounds like you have a ground off on on of your bulbs and the circuit is backfeeding. All four fuses are good? Inspect the grounds near the headlights. They are on the frame rails behind the lights.
Old Mar 18, 2024 | 05:50 PM
Sprinxyzzz's Avatar
thank you for this!
all my grounds are good , 21 & 22 fuze 10 amp under dash are good!
30 amp under hood is good , what is the 4th fuze?
and all the wires are good that connect to the headlights are good. Not saying you’re wrong , you would know more than me , just want to go a little deeper into what you’re thinking. I’m not great at reading wiring diagrams , just confused how it worked roughly 2 weeks ago with aftermarket headlights now with OEM they aren’t. No broken wires , no bad connections , cuz when I switch bulbs around 1 goes bad and the other doesn’t so I don’t think it’s the bulb issue.
Old Mar 19, 2024 | 05:16 PM
Sprinxyzzz's Avatar
Anyone else?
RuckRider2
Jan 18, 2015 09:03 PM
lxdriver
Lighting
Aug 13, 2011 05:39 PM
mdr191
Honda Civic (2006 - 2015)
Sep 24, 2006 08:52 PM
