Head milling...
From: Where the grass is green and the girls are pretty.
I'm planning to mill my B16 head to raise .03:1 CR. How much would I have to mill it to? And doing just .03:1 CR, would there be any side effects such as pinging and cam retardation? Please help, thanks.
if you want to find out, then get the CC size and plug in all the specs of what you know into the compression ratio formula( don't want to post it unless need be), and that will tell you exactly how much to take off to achieve desired CR...or go to C-speedracing.com and go to tech, then find C/R
this might help...
with a stock b20 block, stock b16 head, and reducing the head gasket thickness .001(basically milling the head .001), it raised the compression from
10.205 to 10.233- so that's almost .03. Best way to do it is find the negative space your piston dome takes up and plug that in the equation
[Modified by Emerica, 10:40 AM 11/19/2002]
I'm sorry, I meant 0.3:1 CR . Would milling it 0.3:1 CR be safe? Would there be a hard time timing and retarding it? Would it ping? How much would I have to mill it in order to bump it up 0.3:1 CR?
.010 should bump you up .3...best thing would be to get the piston specs and do the formula again. Any time you mill over .030, you'll be in danger of skipping a tooth on your t-belt if you're not careful.
Ok cool. doesn't milling the head .01 barely surfacing the head? Milling it .01 is totally safe and hassle free right? I don't wanna worry about timing and pinging.
90civic-ZC
Oct 31, 2012 06:15 PM
