Engine swap compatibility
I am absolutely certain this has been flogged to death but I can't find it. I have a mint k24A8 that I'd like to install in an 02 crv with the k24A1 that's using oil. I have no issue changing sensors, etc, whatever is nesessary within reason. Around here a JDM A1 runs around 1800 bucks so if I can repurpose this one it'd be great. Thanks in advance
Probably going to be an intake manifold swap and the rest should work.
Not 100% sure on the coolant block situation on the transmission end of the head. Those were frequently updated and changed.
Don't know if it matters. The '02 ecu might not be compatible with the A8? That's why I'm asking. I can't be the only one who's wanted to do this swap
blkonblkhatch
Mar 8, 2006 07:15 AM
FuNkDrSpOt
Aug 1, 2005 10:18 AM
