Overheating temp rising and going down
Old Mar 15, 2024 | 05:21 AM
Spooderboss2000's Avatar
Default Overheating temp rising and going down
I’m currently stuck with an issue on my 1993 civic dx with the d15b7, recently while i was driving the car it was normal it was cruising 80+ mph then i stopped and it started heating up, now i went got coolant and filled it up it stayed just fine then in traffic it would start to heat up and before it got to the red it would drop down to operating temp then rise and drop down it would mostly drop after i start moving then it would rise up in temp after being stopped sometimes while im stopped it will drop down, now i did refill it again cause it seemed low, but i dont think its a head gasket issue because i checked spark plugs, oil, and there’s no smoke, but there is some bubbles not big but tiny and the heater isn’t heating much but, the car also doesn’t over heat when i start it up in the morning, fans work and everything
Old Mar 15, 2024 | 02:51 PM
95coupeRI's Avatar
Default Re: Overheating temp rising and going down
Does the radiator fan come on while standing and idling? Start the car, idle until the temp rises, and at some point the fan will come on.
dizzi
Jul 18, 2019 04:06 PM
StayKrafty
Jul 16, 2017 05:22 PM
mrJoe
May 8, 2015 05:21 PM
dgouvion
Feb 23, 2014 12:44 AM
rich7777
Feb 6, 2011 11:04 AM
