Honda civic dx 2001 crank no start
I have honda civic coupe dx 2001 manual trans, main problem crank no start, i check:
* the PUMP good (stirring and clicking sound relay good)
it primes to rail, all 4 injectors no spray(no work).
* BATTERY, STARTER GOOD (it crank with power)
* all 4 PLUG COIL IGNITION no working (i test all spark plug good)
ONLY i change the ckp (crank position sensor) still no working
Note the immobilizer green light is off dont do anything. The bulb is good
Comment: its rare to to fail in 4 injectors and 4 plug ignition coil then the panel immo green light dont do anything.
I check interior and engine bay fuses good
I suspectin the ecm bad, new ckp sensor bad and not sure the alternator bad, or other sensor i dont know.
I need ideas where to look and to start the car to use my cheaper code reader obd2.
If you give me the idea thanks for helping me.
slatthuis
Oct 8, 2023 05:26 PM
SeanSmith24
Jul 4, 2020 05:12 PM
