98 civic hatchback charging problem
Old Mar 12, 2024 | 06:33 PM
Twobignuttz's Avatar
Default 98 civic hatchback charging problem
Hello I'm new here looking for help I've searched online and can't seem to find anything...my alternator won't charge its a 98 civic hatchback with an lsv swap running a p28 I've put a new alternator and still nothing my alternator fuse is not blown I have power with a test light to both sides also my battery light does not come on...I have one of those tucked ebay obd2b harnesses only thing I can seem to find is that I should have 4 pins in the alternator square plug but I only have 3 I have power with the ignition on to that orange wire and I assume the other 2 go to the ecu? Any ideas or anyone ever come across this?
Old Apr 23, 2024 | 07:45 AM
Jdatway's Avatar
Default Re: 98 civic hatchback charging problem
Find a fix yet i’m having the same issue
Old Apr 23, 2024 | 08:20 AM
Hasport's Avatar
its the "ebay tucked harness" that is the problem
if you are correct in saying that it is obd2b and your car is a 98 which is obd2a
obd2b is for 99-00 civic. you would need an obd2a harness for 96-98
Old Apr 23, 2024 | 08:52 AM
Jdatway's Avatar
I have a ebay harness too but unfortunately they do say if its obd2a or obd2b
CivicInUse22
May 23, 2013 05:30 PM
GNf racing team
Jan 3, 2013 04:15 AM
MidShipCivic
Acura TL, RL & ZDX
Nov 5, 2006 03:12 AM
0CooL
May 24, 2005 03:16 AM
SOUNDSFAST
Sep 27, 2003 08:26 AM
