Vtec engages late
Old Mar 10, 2024 | 08:21 PM
trilapino's Avatar
Default Vtec engages late
Had some overheating issues and was able to fix by topping off some coolant and air out the bubbles. I had a check engine light but was able to unplug my battery, let it sit for one hour then plugged my battery back on. Turned on car and car run fines and engine light is off. Drove for about 50 miles and no issues, when I floored it I noticed vtec doesnt engage anymore on first gear, but second gear it engages really late like mid to upper 6k. Before the battery reset it was engaging at 5900 no issues. I wasn’t able to check the engine light before I had reset the battery, any pointers?
Old Mar 11, 2024 | 04:20 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
Default Re: Vtec engages late
Check your oil level. What ecu are you running?
Old Mar 15, 2024 | 05:48 PM
trilapino's Avatar
this was the problem, checked my oil and that **** was empty. Filled it up, warm up engine, and sure enough vtec was engaged correctly. Thank you man appreciate it. Running 2000 ITR ECU A04
Joshuacivic88
Feb 3, 2022 06:15 AM
Artbay
Sep 14, 2017 08:38 PM
Blown Stallone
Aug 15, 2015 07:46 PM
lsvtec90
Apr 24, 2005 09:58 AM
