B20VTEC Crank pully question
hi!
im doing a b20vtec build
and the crank pully looks a bit far off? I don’t remember what it’s suppose to look like.
my orientation is the same as the Honda OEM guide
BLOCK ) OIL PUMP GEAR ( CRANK
) & ( are referring to the circle spacers
I don’t have my crank pully bolt atm so I haven’t been able to impact it on and really sandwich it all down ,
but I’m just curious if that ammount of offness is normal? Or if it’ll be fixed once I impact the crank pully bolt on! Thanks!
The crank pulley face will stick out slightly farther than the end of the crankshaft snout. Your pic looks fairly normal, but the angle of the photo could be a bit misleading. As long as the crankshaft timing gear isn't one for an OBD-2 application (has teeth on the rear edge to pulse the crank fluctuation sensor), then having the inner guide, OBD-1 style crankshaft timing gear, outer guide and then the crank pulley IS the correct order. You do NOT use the inner guide when using the OBD-2 style crankshaft timing gear.
BUT
I took it all off and I’m using a obd 1 style crank timing gear , and no longer using the crank position sensor , so I should’ve good then cuz everything fit right up
Regardless of what oil pump you actually have, the OBD-1 crank gear combination from inside to outside is guide, crank timing gear, and guide. For the OBD-2 combination, only necessary if you intend to use the CKF sensor that mounts to the OBD-2 style oil pump, it is only the crank timing gear and outer guide.
Is this more clear ?
