D to B swap no crank
Old Mar 8, 2024 | 05:01 AM
0c00l's Avatar
Default D to B swap no crank
Hello all, I have come here to see if Im doing something wrong or have the wrong starter. I have a Lsv build completed and ready for first start up. 1998 civic CX body/Manual and I have verified the starter works and is getting a 12+ signal to small wire that connects to it when turning key to start. 12+ is connected to the 12mm bolt on top of the starter and is good, ground is good. I can hear the fuel pump come on when turning the key to start just get no cranking. I pulled the starter as it's brand new and when I apply 12+ the wire it pops out like it should and when I apply 12+ to the bottom connection it spins. I guess im not understanding how it gets both spinning and pops out to reach the flywheel. Does the heavy gauge 12+ 12mm send power to the motor to spin it when the 12+ is applied to small wire? I ask because when I put 12+ to the bottom 12mm it spins.
Old Mar 8, 2024 | 05:06 AM
0c00l's Avatar
Default Re: D to B swap no crank
If I jump 12+ from the 12mm in the pic to the small wire it should pop out and spin correct?
Old Mar 8, 2024 | 05:13 AM
0c00l's Avatar
Please delete post. The battery is in the rear of the car and grounding is the issue. Thanks
Nikko9009
Honda Accord 2016- 2017
Jan 6, 2023 08:33 AM
billyhoe
Dec 21, 2020 11:52 AM
stevebell
Honda Civic (2001 - 2005)
Nov 16, 2017 05:29 AM
mafia
Jun 6, 2014 11:26 AM
teler86
Oct 21, 2006 06:24 PM
