Car sounds like its cammed when stock
Old Mar 1, 2024 | 12:31 AM
!ssacsEJ8's Avatar
Default Car sounds like its cammed when stock
I have a 98 civic coupe with the d16y8 in it and it’s been having idle issues, I’ve been trying to fix it and in the process I’ve ran into another “problem” I have no idea if it’s associated with the idle issue I’ve been trying to fix already or if it’s a completely new issue but the issue I’ve been trying to fix is this
So when I’m idling in traffic or say a drive thru and I need to move forward just a little bit whenever I barley touch the throttle to move forward and go back to neutral the car will start to idle high around 1500-2000 rpm’s and it will continue to do so until I keep driving then it’ll idle normal
Ive already cleaned the IACV, Throttle body and replaced the MAP sensor
Few days after cleaning the TB and replacing the Map sensor the car started to idle weirdly as if there were a big cam in the car but it doesn’t do it immediately upon start up
No clue if it’s part of the same idle issue or if it’s a new problem
Old Mar 1, 2024 | 12:36 AM
Velasquez1217's Avatar
Icon4 Re: Car sounds like its cammed when stock
Lowkey vendelo bro.
EM2 Ficial
Honda Civic (2001 - 2005)
Mar 29, 2013 04:33 PM
IntegraType-R
39
Jun 25, 2011 12:44 PM
mikeunreal
Oct 27, 2005 02:39 PM
kihun_cha
20
Sep 17, 2004 03:18 PM
CharmCity
10
Nov 2, 2003 03:53 PM
