Transmission torque mount
I have a 1995 eg hatch, I have a B18B1 with B16 transmission, can I use the single cam torque mount or will I have to get it from another car. I don’t have a single torque mount if not I would have tried it.
If your talking about the rubber mount attached to the subframe (by the steering gearbox), yes you can use the stock soft one from the D-series. You can also use the stiffer rubber one from a Type-R integra for an upgrade.
You will, however, need a B-series T bracket to connect the transmission to the rubber mount. Hopefully you already have that.
The two front lower torque mounts are a different story. Honda uses two different styles that are chassis specific for some reason. So re-use your original rubber portion for those if you can. The brackets in the engine and transmission must be B-series.
