? on power windows and locks.
Old Nov 18, 2002 | 06:34 PM
rob d's Avatar
Default ? on power windows and locks.
Is it plug and play? I pulled everything from an 92-95 EX. I want to put it in a 92-95 DX. Will it just pulg up? Are the wires their in the harness that goes from the door to the body? Do I have to add wires?
Old Nov 18, 2002 | 06:55 PM
underpressure02's Avatar
Default Re: ? on power windows and locks. (rob d)
I am not sure. I got my 92 si with power locks and windows, but I do not know how the kid hooked them up. It is on my list of things to take apart and fix. If you find out can you let me know. Or if you have to wire them and get a diagram of the wiring can you hook me up.
Thanks
Old Nov 19, 2002 | 02:05 AM
Extent's Avatar
Default Re: ? on power windows and locks. (underpressure (wtbimport))
I heard that you need the doors and the wiring harness from the donor car, I dont belive you can use the existing one. That's not from personal experience mind you, I havent even seriously looked into doing it yet myself, I should eventually tho. *sigh* too much to do
Old Nov 19, 2002 | 04:30 AM
92sleepR's Avatar
New User
"Everything" includes the wiring through the body that connects the doors to the fuse box. If you got that you're golden. All you need to do is connect the two power wires to the fuse box by adding them to the correct plug at the back of the box. That, and the ground wire that is bolted to the chassis on the drivers side behind the fuse box.
Mike
bmg123
17
Aug 15, 2011 08:27 PM
-[95cxhatch]-
May 26, 2008 08:50 AM
scottybh
Mar 12, 2006 07:29 PM
EARLdaSQUIRREL
Jan 26, 2005 09:38 PM
