Motor mount broken in the block
Old Feb 12, 2024 | 10:59 PM
Br0kenD16's Avatar
Default Motor mount broken in the block
I still have to do a teardown and look but im now positive this is what happened. Oem bolt sizes are 10x60 and 10x32.5. Im realizing that a helicoil might not fix this if the holes are stripped out since the bolts are so long. Who has successfully fixed this? Or am I screwed and need to buy a block ;(
Old Feb 13, 2024 | 07:14 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: Motor mount broken in the block
You can stack helicoils. These bolts also have long shoulders on them, not that entire 60mm is threaded.
A good TIG welder can also fill the holes in so that they can be redrilled and tapped. You have options.
Newbrand
14
Oct 16, 2019 06:02 PM
DCTegg
Aug 23, 2009 12:00 PM
shytdoode
Jun 24, 2009 10:35 PM
gnccracer20
Mar 19, 2009 06:04 PM
blinger
Apr 18, 2007 07:35 PM
