Honda CR-V & Element 2WD & 4WD Element & CR-V
CRV 2013 relay circuit board replacement
Old Feb 10, 2024 | 05:23 PM
eugenedr's Avatar
Default CRV 2013 relay circuit board replacement
Hello
The wipers on my 2013 CRV do not work in intermittent and low speed modes. I suspect the culprit could be a relay in the relay circuit board but cannot figure it how to replace it. Did anybody ever take the relay circuit board out from the fuse box? I can unlock it and pull it up a bit but not enough to disconnect the connectors from the base. Is there a trick to do it?
Appreciate your help
Old Feb 17, 2024 | 01:33 PM
hound-dog's Avatar
Default Re: CRV 2013 relay circuit board replacement
I'm trying to get that relay circuit board out as well - having the exact same issue as you describe where it can only be lifted out so far without access to the connectors. Hopefully someone replies 👍
roycejohn
Dec 16, 2019 12:59 PM
antonyuk_alex
Honda Civic (2001 - 2005)
Jan 17, 2017 08:54 AM
sam27
Mar 10, 2016 04:24 PM
Juniorhatch
Acura TL, RL & ZDX
Apr 21, 2010 06:58 PM
el_Presidente
May 11, 2003 01:36 PM
