No 5v power to tps and map
Old Feb 9, 2024 | 09:06 PM
Zack M's Avatar
Default No 5v power to tps and map
Just did a Y8 swap in my ef on a P28 ecu. Was going to calibrate the tps, but i realized i don’t have power. i checked the wire at the ecu and still no power. the ecu is getting 12v as it should. i’ve also tried using a P06 which i know works, same story. is there a fuse or relay that needs replaced? i’ve checked all standard fuses and all look okay. the harness is ground to thermostat. Thanks.
Old Feb 9, 2024 | 10:51 PM
Zack M's Avatar
Default Re: No 5v power to tps and map
I fixed my problem. my main fuel relay was plugged in, and it was causing the voltage problem. everything is fixed
aeon117
Sep 5, 2021 01:46 PM
Matt eg
Aug 12, 2016 11:15 PM
egcoupe_900
10
Feb 3, 2012 12:50 PM
civicmulisha
10
Dec 26, 2009 10:56 AM
mockujin
Nov 14, 2002 07:43 PM
