JDM B18C SWAP
So i have a 97 Integra GS and i知 going to swap a JDM 96 B18C type r engine into it. I know i can reuse some of my stock b18b1 parts but what other parts will i need to purchase for the rest of the build?
Really depends on what all the swap comes with. Should be able to reuse your engine mounts (except the AC bracket). You値l need a different engine harness and ecu. Intake may work - typically the ITRs were a touch larger, header is the same (will bolt up but may not be optimal depending on what you池e running). Distributor, intake manifold, power steering are all different. Alternator should be a touch different (mainly the pulley size).
Existing power steering pump should work, but you'll need the correct upper and lower brackets too. I reused my original alternator, but I was also running a GSR crank pulley so I am unsure of the belt lengths.
