Vehicle stalled, cranks, no spark.
Old Feb 7, 2024 | 01:17 PM
Chives's Avatar
Default Vehicle stalled, cranks, no spark.
2000 civic si (Canadian). Car stalled after hitting the driveway bump, cranks but has no spark. Fuel pump primes, battery is clean and has power. Fuses seem good. Tried push starting the car but that also failed, when I tried putting it in gear to start it, it felt like I pulled my brake. Any ideas?
Old Feb 11, 2024 | 08:16 AM
fonkernuckle's Avatar
Default Re: Vehicle stalled, cranks, no spark.
If the motor turns over regular- i.e and the timing belt is not toast (take the distributor cap off to see if the rotor turns when car is cranked then follow this excellent vid to see why you have no spark:
Old Feb 15, 2024 | 01:36 AM
Chives's Avatar
reconnected the battery, tried cranking it to see if the Tachometer worked, nada. Going to attempt the things seen in this video tomorrow
PSHuertas
Dec 2, 2013 06:25 PM
OmgHondaSi
Sep 8, 2011 01:04 AM
szczerbanator
Jun 26, 2009 09:07 AM
DelSlowmo
61
Feb 12, 2009 07:50 PM
rocaveli
May 23, 2005 01:06 AM
