Eg8 sedan battery shorted new battery negative lead sparks bad when trying to connect
Old Jan 28, 2024 | 06:04 PM
Auri's Avatar
Default Eg8 sedan battery shorted new battery negative lead sparks bad when trying to connect
I have a 95 eg ex 5 spd with abs my battery shorted I went to replace it and my negative lead has a bad spark and melts the lead off the terminal I replaced the negative lead and the ground front the tranny to the chaisis I replaced the terminals for the positive lead the ones that go to both fuse boxes and I still have the same problem I've looked over the charge harness and it doesn't seem to be shorting out can anyone please help
Old Jan 29, 2024 | 03:11 AM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Eg8 sedan battery shorted new battery negative lead sparks bad when trying to con
Make sure you don't have a bolt or something metal touching the starter power terminal.
And check all the fuses
Old Jan 29, 2024 | 04:28 PM
spAdam's Avatar
Loved
Community Favorite
Are you confident that YOU are connecting the polarity correctly? Did you accidentally replace the battery with a group 51 instead of a 51R?
wchowc
Jan 19, 2012 06:52 AM
Cobalt_daddy
Dec 31, 2011 07:18 AM
potat5656
Aug 4, 2011 12:48 PM
crxh22project
19
Mar 23, 2005 08:19 AM
GroundZer0 336
Mar 6, 2004 05:55 PM
