Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Civic FN Airbag System
Old Jan 28, 2024 | 11:06 AM
enculescu's Avatar
Default Civic FN Airbag System
Hello team,
I own a Civic FK3 from 2009.
Some weeks I got hit by a red light crosser on the right rear side.
During the incident, the curtain and front seat airbag deployed, although I was alone in the car.
Since the insurance company is bankrupt, I need to fix it on my own, it will take 2 years to recover the money for my damage.
I already changed the rear suspension and the rear door. Most of the parts I got them from scrap yard.
Do you know if I change the seat airbag and curtain, if I need to replace the airbag module (control unit) and also do I need to replace the crash sensor located on the middle pilar?
I am also wondering if I need to register the new airbags into the system.
Before the crash I never had any airbag or SRS check light on the dash, though I was never able to connect to the airbags module using HDS.
Thanks a lot for the help, any info is much appreciated!
Old Jan 29, 2024 | 06:11 AM
Ryanthegreat1's Avatar
Default Re: Civic FN Airbag System
Wow that's some ****.
You can have the SRS unit reset by a company that specializes in that. Not horribly expensive.
You will need a new impact sensor and new air bags. Not sure if the FN has seat belt tensioners, it probably does. That will also need replacement.
Old Jan 29, 2024 | 10:34 AM
enculescu's Avatar
Awesome. I will actually buy an airbag unit as it is hard to find someone good and serious in Eastern Europe for such task.
Thanks a lot for the help Ryan!
Bethkris
Honda Insight & CR-Z Hybrid
Feb 25, 2016 06:10 AM
si1992
Apr 4, 2014 04:30 AM
97civicguy
23
Dec 30, 2013 05:06 AM
MJA829
Sep 20, 2012 05:39 AM
liquidride59
Honda Civic (2001 - 2005)
Jan 29, 2007 01:33 PM
