Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Need help determining source of oil leak
Old Jan 25, 2024 | 12:45 PM
pfitz321's Avatar
Default Need help determining source of oil leak
Hey fellas,
I recently changed out my timing belt, water pump, crank and camshaft seals, oil pump seal, and oil pan gasket. Upon completion and after a few minutes of letting the vehicle run, there was a small oil puddle on the ground. The leak appears to happen only while the engine is running, and by the crankshaft hump. See video…. Would it be from one of the seals or is it the oil pan gasket? Any help and or suggestions are welcomed.
thanks
Oil is dripping while the engine is running only, about a drop every second or two. No leaks when vehicle is off.
https://drive.google.com/file/d/1fM-...w?usp=drivesdk
Old Jan 29, 2024 | 02:00 PM
benchwarmer's Avatar
5 Year Member
Default Re: Need help determining source of oil leak
I believe there is a crank seal there , You should use quality OEM parts
VenomRx
Dec 18, 2013 11:58 AM
Looney2002
Acura TL, RL & ZDX
Mar 24, 2013 05:08 PM
wtsapexipowerfc
11
May 28, 2011 04:47 AM
GruvyTune
Jul 5, 2002 08:57 AM
