Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Engine seized up???
Old Jan 18, 2024 | 01:22 PM
MrNavy's Avatar
Default Engine seized up???
02 civic 1.7
Car was on idle for 10m then from nowhere the engine made a grinding sound I thought I put it on gear by accident and stalled, but it wasn’t the case, I tried to started it and it was making grinding sounds, then I went to look under the car bc I heard some leaking going on and the oil came out, all of it, not sure from where yet, I put some oil and the car don’t start just grinding noises hope somebody can help me
Old Jan 19, 2024 | 04:28 PM
sirtef99's Avatar
Default Re: Engine seized up???
Try and turn it over by hand, that'll tell you if it's seized.
Old Jan 19, 2024 | 06:03 PM
MrNavy's Avatar
welll I took the coils out, they have oil so maybe the engine is gone
Old Jan 24, 2024 | 01:54 PM
benchwarmer's Avatar
5 Year Member
Oil on the coil towers is from the bad valve cover gasket . , Where is the oil leaking from ? If it ran dry on oil till it stopped then it's probably toast at that age and milage
ferio252
Dec 15, 2010 12:29 PM
wolf95
Oct 27, 2009 01:08 PM
revhardEK
Jan 25, 2008 06:05 PM
EM1FORLIFE.
May 16, 2006 09:45 AM
