Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 Civic Flashing Green Key (Crank No Start) Please Help
Old Jan 15, 2024 | 04:08 PM
Joshwahh's Avatar
Default 2005 Civic Flashing Green Key (Crank No Start) Please Help
Hey guys, I started my car and drove out and within a minute of driving the car completely shut off. I was able to get it back into my driveway to try to figure out what was going on with it however, I was not able to figure it out. I didn’t notice however that I had a flashing green key light which after I did some research, it said that the key may be bad or the immobilizer May have lost the program I had someone come by and tried to reprogram it however they were not able to get to my ECU. He told me my ecu may be bad so I found someone on Facebook marketplace and bought a new ECU immobilizer ignition switch and a key. I swap this all over and I’m still having the same issue , has anyone seen this before ?
Old Jan 15, 2024 | 04:13 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2005 Civic Flashing Green Key (Crank No Start) Please Help
Check the car battery and alternator first.
Old Jan 15, 2024 | 04:15 PM
Joshwahh's Avatar
thanks for responding I had them both checked and they were good. I also noticed that I couldn’t connect to the ecu through my scanner at all.
Old Jan 15, 2024 | 04:26 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Check the following fuses:
Under-hood: Fuse No. 9 (10A); Fuse No. 2 30A)
Auxiliary Under-hood: Fuse No. 32 (15A) - This is the small box next to the larger under-hood fuse box.
Under-dash: Fuse No. 10 (7.5A)
Old Jan 15, 2024 | 04:29 PM
Joshwahh's Avatar
Yes, I did check all these and they all seem fine. The only one that sounds unfamiliar is the auxiliary under hood fuse I’ve never seen that box and I don’t think I have one under my hood.
Old Jan 15, 2024 | 04:34 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
My mistake, somehow I kept thinking this was a 2005 CR-V.
Old Jan 15, 2024 | 04:35 PM
Joshwahh's Avatar
that’s ok I am just confused on what else to do lol
Old Jan 15, 2024 | 04:55 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Did you check the ground connection G101? Clean and tight?
Old Jan 15, 2024 | 04:58 PM
Joshwahh's Avatar
yes I too the intake off and cleaned it.
some came by and told me the auto cruise module could be the issue cause it has a few wires that run to the immobilizer. Could this be true?
Old Jan 15, 2024 | 05:04 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Cruise control is part of a separate circuit than the immobilizer system circuit.
Old Jan 15, 2024 | 05:05 PM
Joshwahh's Avatar
Yeah that’s what I thought so good thing I did not buy that part. However, I must also mention that the car is not going into neutral drive or reverse unless I use the key release so I’m not exactly sure what is causing this issue.
Bryan08
Aug 29, 2017 07:14 AM
SinkTip
Jul 10, 2016 03:53 PM
jrm
May 6, 2010 05:57 PM
FuNkDrSpOt
Jan 3, 2007 10:04 PM
