2001 Honda CRV - Clean alarm install with telematics and remote start
I did a similar install on my 2000 civic, so here I bought an alarm with drone telematics so I can start the CRV from my cellphone where I am. To do this I needed to design a bracket to hold the unit (just like the factory would). I did this in CAD, and printed it out of high temp ABS.
my car is an auto- so I have no clutch. I can use the space where the clutch would be, and the top support fastener point. first try, just a quick print I needed a bracket to hold down the main unit. (simple enough) the top attachment is for the clutch I believe telematics unit (for cell phone access) goes above the glove box on the passenger side. Custom bracket made and printed. you would think this was stock it fit so nice. I actually left space next to it to I could mount the shock sensor (sorry not included in the picture)
Re: 2001 Honda CRV - Clean alarm install with telematics and remote start
Everything is connected with a harness quick connection to the factory wiring. Nothing is hardwired. Here is a quick few pictures before I did the final clean up.
My car has no factory security module - so the green plug has no home. (it is an LX) All of my connections are heat shrinked and soldered. I used micro relays with the alarm to activate the liftgate glass in the back, and for the horn/siren combo.
