Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
2014 2.4 engine - startup rattle
Old Jan 13, 2024 | 08:52 AM
Bibby 3340's Avatar
Default 2014 2.4 engine - startup rattle
I finally solved the startup rattle that occurs when the car sits for several hours. There is a Honda Service bulletin that states this is caused by timing chain tensioner. I replaced the tensioner with a Honda OEM part and it made no difference. I then researched how Honda VTEC operates on this engine. I then purchased a VTEC solenoid. Again, the startup rattle continued. I also had a minor problem where while driving at times, the engine would seem to alter its power range as I drove; this is the best I can describe it. I again researched the VTEC system and decided to replace the VTEC spool assembly. Upon starting the car this morning, the startup rattle is gone! I did purchase the actuator spring that I did not use. I also just purchased the Honda actuator gear and will keep that for down the road when I get to a point that I need to put in a timing chain kit. Tomorrow will adjust the valves and probably will put in the spring........
update: the startup rattle came back. Purchased VTEC actuator spring and installed it. Been a week or so and rattle is no more…..
Old Mar 27, 2024 | 04:34 AM
Hondanutandbolt's Avatar
Default Re: 2014 2.4 engine - startup rattle
I'm familiar with the older spool assemblies. This new cam phaser stuff is a bit tricky. I just got a 13 accord sport with a manual. Unfortunately it has the common issues, like startup rattle. Where is this spring that you installed? I'm guessing it's a backflow preventer to maintain oil in the phaser. Was it in the vtec solenoid?
Old Mar 27, 2024 | 08:36 AM
Bibby 3340's Avatar
I purchased the spring and and installed it. It did not help. I am actually getting ready to replace the VTC Actuator. I am waiting for a few gaskets to arrive to begin. my model 2014 accord, I need to remove intake, high pressure fuel pump, fuel pump base before I can get to the cam. Kinda a pain but not too big of a deal. I have the the new actuator on hand. I previously replaced tensioner and VTC oil control valve as well as the Valve Assembly Spool. It is apparent at this point, the actuator is the problem.......
JonasB
May 6, 2016 09:14 AM
damongreg
15
Jul 10, 2010 09:56 PM
Terence
Jul 1, 2005 01:12 PM
