Honda CR-V & Element 2WD & 4WD Element & CR-V
Need help and advice. Car will not stay running. Died on the highway. P0341
Old Jan 7, 2024 | 09:12 AM
Turthrex's Avatar
Default Need help and advice. Car will not stay running. Died on the highway. P0341
I’m having an issue with my 2003 CRV the car has 240,000 miles on it. I was coming off the exit ramp and the car just completely died on me. It will not stay running when I start the car it immediately starts to misfire really bad and the second you take your foot off the gas, it dies, it’s throwing the P0341 code the only thing I have checked was the timing chain and it’s tight. It does not seem like it has any play at all. I have also swapped the two camshaft position sensors to see if it made a difference and it did not. And I have replaced the VTEC Solenoid the one on the side of the engine just below the valve cover with a junkyard one and still no luck
Old Jan 7, 2024 | 10:00 AM
mtnbikeracer76's Avatar
Default Re: Need help and advice. Car will not stay running. Died on the highway. P0341
A quick Google search revealed that P0341 is for your camshaft position sensor. The ECM doesn't see where the camshaft time is in relationship to it's programmed data. A mismatch. So the CEL is thrown and this code comes up.
Time for a replacement.
Old Jan 7, 2024 | 11:10 AM
Turthrex's Avatar
I know I have already replaced the camshaft position sensor and I’m still having the same issue
Old Jan 7, 2024 | 11:33 AM
Did you replace both of them? There are 2 camshaft sensors.
Old Jan 7, 2024 | 11:53 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
It is more likely due to a stretched timing chain, not the sensor.
Old Jan 7, 2024 | 12:03 PM
starchland's Avatar
Check chain stretch and tensioner position.
Old Jan 7, 2024 | 12:52 PM
Turthrex's Avatar
I did yes
Old Jan 7, 2024 | 12:53 PM
Turthrex's Avatar
I checked the chain it’s really tight
Old Jan 7, 2024 | 02:01 PM
Honda's troubleshooting flowchart shows the following for Code P0341:
  • incorrect timing
  • damaged or stretched chain
  • clogged or stuck open/closed VTC (Variable Timing Control) oil control solenoid valve
  • faulty VTC actuator
  • damaged camshaft position (cmp) pulse plate
Honda P0341
Found this with a little digging here.
Old Jan 7, 2024 | 05:10 PM
starchland's Avatar
Great, but is it stretched?
history of oil change neglect?
Old Jan 8, 2024 | 03:26 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The procedure to check for a damaged or stretched cam chain is by measuring the cam chain auto-tensioner rod length. If it’s more than 13.5 mm, the chain is bad and must be replaced, along with the chain auto-tensioner.
RyanWhite
Apr 26, 2016 10:44 AM
DC2_ALL MOTA
Mar 26, 2006 11:40 AM
geminis2k
Nov 10, 2003 01:14 PM
jr_istheman
Apr 7, 2003 05:58 PM
