Ek coupe OBD1 SWAP NO RPM NO SPEED NO VTEC
I just bought a ek coupe shell and swapped My obd1 b20v from my eg9
Car starts up fine with fuel pump relay 5-7 pin bridged
I do not have rpm neither speedo and vtec doesn't engage
any solutions?
any solutions?
Your vtec is out because of having no speed. Or a corroded connector at the speed sensor. 96-00 civic get there rpm from the ecu. So youll have some wiring to do
https://technet.ff-squad.com/wiring.obd1.htm
I don't think you're going to have a proper working swap using any obd2 ecus, go obd1.
Vss should be fine wiring wise. Check the sensor or connector at the sensor.
Blue wire on dist could go to tach if you want to work hard. Like spAdam says, jump the ICM to NEP pin (on obd2 harness) right at the ecu.
Sorry heres this too https://www.ek9.org/index.php?attach...atics-gif.200/
Icm and nep same pinout on ecu side?
That’s the obd2b pinout.
He said his car is obd2a: https://www.ff-squad.com/technet/wiring.obd2a.htm
Bridge Icm to nep?
Kamouflaz Evo
Jan 1, 2024 09:27 PM
Kamouflaz Evo
Dec 17, 2023 03:05 AM
phan321
Aug 3, 2006 06:47 PM
