5th gen prelude Engine Clunking and Cylinder 4 Misfire
Old Jan 1, 2024 | 10:45 AM
rexdmatt's Avatar
Default 5th gen prelude Engine Clunking and Cylinder 4 Misfire
Hey fellow honda enthusiasts,
I've been dealing with a persistent clunking sound coming from my engine. I've gone through all the usual steps to address a misfire, but the issue seems to persist.
I've replaced the spark plugs, wires, the ignition coil, distributor, and even the fuel injectors/pump/filter, but the clunking sound remains. (it is properly timed and has good compression across the board) Has anyone encountered a similar problem before, or does anyone have suggestions on what might be causing this issue? I'm attaching three videos to illustrate the problem, hoping that visualizing it might help identify the root cause.
Video 1: Noise from engine bay
https://youtu.be/rh9LnkuMRZA?si=8bUYthwhSK7JFtiK
Video 2: Noise from exhuast
https://youtu.be/bdPFPXiVnTQ?si=yPHnfThhULhuS68h
Video 3: Noise when revving
https://youtube.com/shorts/NrbB_YRvYmU?si=N2lfb1OfnVRUh413
Your insights and expertise would be highly appreciated! Thanks in advance for your the help.
Old Jan 2, 2024 | 02:25 AM
TimiK's Avatar
10 Year Member
Default Re: 5th gen prelude Engine Clunking and Cylinder 4 Misfire
do compression and leak tests
triskpin
Sep 13, 2009 04:44 PM
johnrau
Apr 3, 2006 12:29 PM
mrqwink
Dec 3, 2005 05:30 AM
sleeping_forest
Jun 13, 2003 09:41 PM
