Honda Civic (2016 - Current) 10th Generation Civic Forum Civic / Si / Type-R Discussions
Sponsored by: CARiD
Not working, Windows, door locks, sunroof trunk release passenger side mirror. Need h
Old Dec 28, 2023 | 03:33 PM
gmayer's Avatar
Default Not working, Windows, door locks, sunroof trunk release passenger side mirror. Need h
As the subject line says, the windows' door locks, sunroof truck release, and passenger side mirror do not operate from the driver's door. The rear windows will operate from the individual doors. None of the above items work from the main driver-side control panel. When using the key fob, there's no sound that the doors are locked.
I have done a continuity check on the fuses and the voltage, and it seems fine.
I've checked the two relays, but I'm not sure which one to check that's above the interior fuse panel, and they are operating as they should be.
Have you seen this before? Any tips on fixing this?
Thanks for your help.
Old Dec 30, 2023 | 02:29 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: Not working, Windows, door locks, sunroof trunk release passenger side mirror. Ne
if its all happening from the drivers door it sounds like you isolated it, could it just be a bad switch panel?
have you taken the door panel off and checked the switch harness for continuity?
Old Dec 31, 2023 | 12:20 PM
gmayer's Avatar
Old Dec 31, 2023 | 12:21 PM
gmayer's Avatar
UPDATE
I replaced the window control unit on the driver's door, and it's all working now—part number 35750-TBA-A31. The inside trunk release is still not working. I guess I will replace the button next.
motegicivic
27
Jan 19, 2015 11:03 AM
wdutton
Dec 1, 2011 06:52 PM
Kataku2K3
Feb 11, 2007 02:06 PM
hondacivichatch
Sep 21, 2005 03:09 PM
Vinny Chase
Audio / Security / Video
Jun 22, 2003 05:06 PM
