Power door lock issue
I have a 96 civic 2dr ex with factory keyless.
I was working on the passenger side window molding, had the door panel off.
I put the door panel on and the door locks will not work. I did not touch any door lock connectors, the only connector I unplugged was for the window which works.
What happened, did some get unplugged or messed up when I put the panel back on?
Note: drivers door lock and passengers side does not work, with inside switch and keyless fob.
I checked fuses, and they seem ok, I check keyless fuse, door lock fuse which is shared with moon roof and moon roof works ok.
Re: Power door lock issue
Ron what fuse is that for by the way? That is not the one shared with moon roof is it, because the moon roof still works?
You take a multi meter and put each probe on the little metal tabs on the top? With key on or off does it matter?
Start by doing the tests for cavity 4 and 12 (power and ground):
Thanks Ron, I am wondering this say for instance there is a problem with the passenger side wiring to the actuator , say it got unplugged when I was working on it etc. Will it affect both doors, seems strange all of the sudden I was taking the passenger door panel off and now they both don't work?
Ok, guys I was doing some reading, and one post said the drivers power lock switch goes bad it can take out the whole system...is this true?
Also, anyone know how to test the switch itself?
Set multimeter to read resistance on lowest Ohm scale. Touch one meter lead to indicated terminal and other lead to body ground (e.g., metal frame under dash).
Stop avoiding the input tests. They will pinpoint the problem.
Can anyone confirm if the passenger side actuator is unplugged will it knock out the whole lock system?
After you jump the ports do you then hit the lock button to test?
Ron, when reading the pinouts above, you can manually check operation and I guess bypass the control unit to make the doors lock and unlock, my question is you jump the connectors they indicate above to do this?
Thanks again, I wanted to bypass the control unit to at least see if I can get the locks to work, if so then chances are the control unit is bad.
If not then I know there is a bad ground, short, or cut wire maybe at the door jam.
