Honda CR-V & Element 2WD & 4WD Element & CR-V
2006 CRV ECM change
Old Dec 27, 2023 | 07:07 PM
2006 CRV - RMJ's Avatar
Default 2006 CRV ECM change
Hello everyone. My name is Robert and I own a 2006 CRV - UK. This is my 1st post here and if I need to post this in another area, please let me know and I will do so. The question is I don't have my original ECU and ignition assembly (long story). I do have original ECU box number. I have located a few used plug and play ECUs with key and transponders. If the part number is same as my old ECU, will these work? Any input will be appreciated.
Old Dec 27, 2023 | 10:45 PM
Ryanthegreat1's Avatar
Default Re: 2006 CRV ECM change
Yes but you will still need to program the immobilizer as the MICU is also part of the system and they will all need pairing.
Old Dec 28, 2023 | 06:39 AM
Thanks for the response. Which is the immobilizer? Where is it found? Is it the one circled in red?
I understand that it is all coming from the same vehicle. The ECU, key, and the immobilizer. It still needs programming? Pardon my ignorance. Just want to make sure. Thanks again.
Old Dec 28, 2023 | 07:31 AM
Yes that's the antenna for a part of the immobilizer system. If you don't have it you will need it.
ECU, MICU, and Antenna all need to be paired together and then have your keys programmed in.
Old Dec 28, 2023 | 08:05 AM
Old Dec 28, 2023 | 08:13 AM
Last question. I've attached a picture of what Iam looking at. If all these are from a working vehicle, is there something missing here that I still need to program?
Old Dec 28, 2023 | 08:37 AM
The MICU, it's part of the under dash fuse panel.
Old Dec 28, 2023 | 09:36 AM
@Ryanthegreat1 So to answer my own question, these are not plug and play as advertised. The existing MICU under my dash then needs to be programmed to actually work! I'm very disappointed 😞. Thanks for the response and information. Just wanted to make sure I didn't spend money on this and be disappointed if it didn't work.
Old Dec 28, 2023 | 09:58 AM
It will work but you need the tool or someone with the tools to do the immobilizer configuration.
Old Dec 28, 2023 | 06:26 PM
starchland's Avatar
I changed my Ecu and was able to add existing keys to the ecu/immobilizer using an Autel ap200 dongle. Not sure if that helps.
Old Dec 29, 2023 | 04:58 AM
@starchland I'm willing to give it a try but I need to replace the ECU along with matcging immobilizer and key, all from a used vehicle with same number as my old one. I believe problem will be programing the MICU under the dash and I'm not sure the Autel will do that.
Old Dec 29, 2023 | 05:05 AM
I do have a ThinkDiag dongle. Since i dont have any of the items, I haven't been able to try it.
Still unwrapped!
Old Dec 29, 2023 | 05:48 AM
I use an Autel 906 for all my immobilizer stuff. I have a 200 but not for Hondas. It does look like the same software on the 200 as the 906.
Old Dec 29, 2023 | 06:24 AM
@starchland @Ryanthegreat1 Is this the right one, Autel MaxiAP AP200?
Old Dec 29, 2023 | 06:41 AM
starchland's Avatar
Yes.
MICU needs to be coded to the key/ecu? Can someone elaborate on that?
just trying to make sense of this. I have changed my ecu before without issue. Micu and key are coded together as well?
Old Dec 29, 2023 | 07:12 AM
@starchlandMy original post. I need to replace what's on the picture in this thread. My original MICU is still in my 06 CRV. I am reading that the MICU needs to be programmed to the components I am wanting to purchase from a junked CRV with the same ECU number 37820-PPLA-93.
Old Dec 29, 2023 | 07:16 AM
Originally Posted by starchland
Yes.
If you replaced your ECU and then used the Autel immobilizer function for ECU replacement then it coded in the MICU for you.
The MICU started to be included in the immobilizer handshake when the K series came about. It was an effort to make the immobilizer that much harder to bypass for theft reasons.
Old Dec 29, 2023 | 07:44 AM
starchland's Avatar
ty for the clarifimacation
Old Dec 29, 2023 | 08:21 AM
sf340b's Avatar
5 Year Member
Yes.
2002 CRV FWD, AT, CRZ, Japan build and I changed the MICU with a junk yard find and it did not need to be programmed. I did it again with the correct year MICU and it worked also.
The programming is in the immobilizer module and the ECM.
I was wondering about a set (Module, ign, keys, and ECM) and if it would work but have not tested that.
Old Dec 29, 2023 | 08:28 AM
2005+ is a different ECU
Old Dec 29, 2023 | 08:31 AM
@sf340b I've read on other posts that in earlier models, there was no need to program MICU. Unfortunately for 2006, it needs the be programmed as a set with all the components.
Old Dec 29, 2023 | 08:36 AM
@Ryanthegreat1 I can keep the MICU currently under dash and program it with the Autel, correct?
Old Dec 29, 2023 | 08:59 AM
Yes
Old Dec 29, 2023 | 09:22 AM
starchland's Avatar
this is what I figured (immobilizer/ecm) and from experience as well. Mine is 05 dbw fwiw.
Old Dec 29, 2023 | 10:07 AM
@Ryanthegreat1 Thanks for the help. Once I gather the parts and the Autel MaxiAP AP200, I will attempt this. Once I do, I will report back for future reference in case someone else needs help.
