problems with ECU honda civic 95 injectors not pulse
Problems with the Civic P29 ECU In my country, the Civic came with the P29 ECU, it is very similar to the P06. Let me summarize, I have a year 95 civic d16a9 DOHC engine in your country it would be like d16zc DOHC. The car started to fail on the road, I stopped and opened the hood, lifted a cable to test which cylinder was failing, suddenly lifting cylinder 4 turned off. and it didn't want to turn on. I managed to tow it home and while testing I noticed that the injectors lost their pulse. If I pour gasoline through the intake it starts but it goes out as soon as the burn occurs. I have a friend who provided me with his ECU and with his. The car starts clearly as it is programmed for h22, I think it works very well. So I open the ecu and I notice that it has several repairs. I come to the forum to see if it has happened to anyone and what part of the ecu they recommend I check. I assume it's the ECU. Because if there were ground, cable, false contact, injector or connector problems, it might not start with the other ECU.
Lance Darling
Honda Civic (2006 - 2015)
Jun 18, 2019 01:36 PM
crxmadness
15
Jun 11, 2014 06:38 PM
