1998 accord v6
Old Dec 10, 2023 | 09:56 AM
Dan87's Avatar
Default 1998 accord v6
Hello, I’m looking for advice with my mothers car. It’s a 98 accord v6. 200,000 miles. Recently it started surging and and almost shutting off like a bad hesitation only when driving and trying to accelerate. Car idles fine annd revs fine while it’s in park or nuetral , and when it throws a fit while driving if you put it in nuetral it is fine. When you put it back into gear the fight is in again when trying yo accelerate. I have replaced the main relay, iacv, and tps(calibrated also). There are no engine codes except and Evap code. Anyone have any ideas?
Old Feb 23, 2024 | 08:45 AM
Martincg1's Avatar
Default Re: 1998 accord v6
Currently dealing with the same issue So far I replaced
Spark plugs
ignition coils
idle control valve
TPS sensor & calibrated
Map sensor
fuel regulator and Fuel Damper
upstream o2 sensor
PVC valve
EGR also cleaned all ports
No vacuum leaks
Good compression test
good fuel pressure
did you ever find out what was causing yours
Saeed Khalaf
Jun 11, 2017 04:31 PM
swamprabbit
Sep 19, 2016 05:01 PM
meekmon
Sep 14, 2015 05:05 PM
Juan_Pablo
Jun 25, 2013 12:50 AM
Ercol215
Apr 30, 2013 06:29 AM
