Suspension & Brakes Theory, alignment, spring rates....
2008 Honda CR-V Toe Alignment not adjusting
Old Dec 5, 2023 | 11:57 AM
Ravi1's Avatar
Icon4 2008 Honda CR-V Toe Alignment not adjusting
Can someone advise what could be the cause of my rear toe alignment not adjusting. Could it be a bad knuckle rubber/bushing? (not sure if that applies to the knuckle). The mechanic is stating that when turning the bolt he can see the alignment going where it needs to be but then suddenly just pops back to where it was at the beginning. Currently been through 2 pairs of tires for the rear (on my third pair) and I want to fix this before buying another set. Any help would be appreciated. Picture of the part is attached. the toe bolt goes through one of those ends at the double rubber and the upper control arm connects to the end with the single rubber.
95ejjj
Suspension & Brakes
May 21, 2010 09:46 AM
project-boosteD
Suspension & Brakes
Jan 27, 2009 01:58 PM
alwaysoverkill
Suspension & Brakes
Jan 13, 2006 07:43 AM
CivicEK.PDX
Sep 12, 2002 06:42 PM
