Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Codes P0108 and P0113 After Valve Adjustment
Old Nov 30, 2023 | 12:05 AM
Ayverex's Avatar
Default 04 Honda Civic EX: Codes P0108 and P0113 3
Vehicle - 04 Civic Ex 1.7L
Today I did the valve gasket, plug seals, cam plug and valve adjustment, i disconnected the IAT and MAP for some more room, I didn't do the reset yet (will do so in the morning). Now it starts smelling like fuel and throws codes P0108 and P0113. Before it was throwing P0135, I think, which ever is the Downstream O2 Sensor, with the maintenance required light.
Will changing o2 sensor bank 1 sensor 2 fix it?
I provide the OBD2 scans so you can see how much I screwed up lol Any feedback would be greatly appreciated.
Old Dec 4, 2023 | 05:03 AM
Fineedge's Avatar
Default Re: Codes P0108 and P0113 After Valve Adjustment
Did you double check all electrical connectionsonre assembly! Disconnect them and reconnect.
rushabh21
Dec 21, 2010 08:44 AM
lowered94accord
May 7, 2007 09:24 PM
zman
Jan 1, 2006 08:04 PM
NR_si
Jul 1, 2004 03:14 PM
Aquafina
Jun 18, 2004 09:55 AM
