Help fix my del slo
Old Nov 7, 2023 | 04:51 AM
93Slo's Avatar
Default Help fix my del slo
New to Hondas. I am decent with cars and have built a couple in the past. Always wanted a del sol and a rust free one popped up in my price range and I jumped on it.
1993 SI auto car.
was told it was swapped to a d16z6 but from poking around on here I think it is the factory motor option.
it’s been swapped to manual and the speedo doesn’t work, I don’t think Vtec is working, was told speedo stopped working as soon as manual swap was done. Still has auto brake pedal. Looking to finish/fix the swap and repair a couple leaks on the engine/trans. The rest seems to be working as it should.
can some one point me in the correct direction for the correct way to manual swap this car? I want to go through and check all the work done and finish/fix what is missing or wrong.
what do I need to replace the brake pedal? I manual swapped a dodge neon and the brake pedals where one assembly with the clutch so pull the auto brake pedal, install manual one and clutch pedal was included.
any help is appreciated, I will keep poking around in my spare time to see if I can drum the swap how to up.
tha ks for any help you can provide!
Nozzy93
Feb 22, 2016 12:26 AM
slambedcivic
11
Aug 20, 2009 05:14 PM
xSKEETx
15
Dec 13, 2007 11:49 AM
justgotapre
Jan 19, 2006 04:15 PM
crx_91si
May 23, 2004 01:22 PM
