Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Throttle cable loose from gas pedal.
Old Nov 5, 2023 | 10:46 AM
myx's Avatar
myx
Default Throttle cable loose from gas pedal.
Hi Guys,
Is it possible to fix the rubber part to the plastic piece on gas pedal with strong glue, mine has been separated from the plastic.
Old Nov 6, 2023 | 05:45 AM
myx's Avatar
myx
Default Re: Throttle cable loose from gas pedal.
Found the stupid slack in the throttle body side one turn was enough to make it completely loose. Might have come off while cleaning throttle. Made the turn cable back up on the winding it became tight.
I thought the rubber had worn off as show in pic.
Old Nov 6, 2023 | 08:13 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The slack is always taken up at the throttle body end... and if you can't, then you have the wrong cable/bracket combination. Glad you fixed it.
maxogsr
Jun 30, 2013 03:32 AM
VietCloud7
May 6, 2008 04:46 PM
Yeung
Jun 3, 2004 09:12 PM
midorigreen.
Mar 16, 2003 07:40 AM
Cat
Sep 30, 2002 06:48 AM
